Discussion topic: Connection issues
This message was authored by: AB1291
Connection issues
Hi my phone keeps losing connection and using all my data, Iit is only about 15 feet from the hub although it is in another room
This message was authored by: Nanna-T
Re: Connection issues
Mines the same and my sky puck has lost WiFi connection as well, but the service checker says theres no known issues
@AB1291 a lot depends on the wall between the two rooms and other obstructions like radiators. Make sure the hub is out in the open and off the floor on a surface well away from other equipment. If your home has brick internal walls these inevitably will reduce signal levels while any metal will bock the signal completly its simple physics. Turn off settings like WiFi assist on the phone as that will switch to using mobile data where it is faster.
