1
This discussion topic has been answered Discussion topic: No wifi
This message was authored by: Kirstyspiers28
No wifi
Ive got no WiFi. Ive done a check on your app and it says all fine but I have no Internet! The orange light is on the box!! This keeps happening.
Re: No wifi
@Kirstyspiers28
The hot weather won’t be helping but use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
Re: No wifi
@Kirstyspiers28
