Discussion topic: Connection issue
This message was authored by: Woodcock1
Connection issue
My TV went off last night saying no internet, I tried all the usual stuff but nothing worked, I have run a test on the app and it says all looks good but I still can't get any WiFi or connect the stream puk.
Can anyone advise please?
This message was authored by: Mike46540
Re: Connection issue
I'm in Cumbria and internet is down. Mon am. Sat waiting for it to come back so I can work.
@Mike46540 run the connection test in the My Sky app over a mobile connection which will tell you if there is a known fault. If there isnt report the fault to Sky so they can get it fixed.
