Discussion topic: Connecting phone line
This message was authored by: Tracy117
The little socket that you put into to uk one didn't fit my phone plug  so I had to put it in the one next to it. Is that okay ?
Re: Connecting phone line
@Tracy117 if your phone socket has two conections the larger one is for the phone thecsaller one is for the internet connection. If your phone gives you a dialling tone it is connected correctly.
