Discussion topic: Conection issue
This message was authored by: Rhii11
Conection issue
Hello
we have just switch to you for are wifi and its been on 2 weeks today and its rubish it connets to are phones and ipads with full signal strengh but wont load anything or work to the poin need to turn wifi off on phone to be able to use it and hot spot to the ipad for that to work witch is not what id be exspecting to do but its not just are phone we have 4 CCTV camras wotcj it connects to but aignal very poor when not even far away from hub and wont load the live stream and wifi so slow never had any issue with last provider so seems to be an issue with either your box or connection
look forwards to hearing how tou can fix this
kind regards
Re: Conection issue
@Rhii11 You are not talking to Sky by posting in this forum so nothing will happen until you make direct contactvwith them.
If you woulld like help from forum members who are customers like yourself then it would help if you gave some more information likecspeeds youbsee near the  hub, a few details on your home like where the hub is and whether your home has solid internal walls including the connection stats for yourcSkybhub would help see Find your Sky Broadband router statistics
If you call Sky they will try to sell you an add-on package tonextend  wifi coverage which may be tgecanswer but there can be cheaper alternatives. If you are in the first 31 days of the Sky service you can cancel without charge if you want.
