Discussion topic: Mysky app not true speed for slow broadband
Message posted on 15 Jun 2024 06:46 PM
So for weeks now our broadband has been getting slower and slower, and the musky app constantly says we are getting the fastest we can although fast.com shows different. Then there is no broadband and I check via mobile data it still shows full speed. When I try to call it just rings and rings then cuts me off. Is this just me or are others having this issue?
Message posted on 15 Jun 2024 06:48 PM
Re: Mysky app not true speed for slow broadband
Could you post your router stats
Message posted on 15 Jun 2024 07:38 PM
Manufacturer. Sky
I hope this the correct information
Message posted on 18 Jun 2024 11:27 AM
The test you are running on your phone is over WiFi which can be a lot slower than the line speed that the My Sky app shows. Can you try running a test over ethernet?
Message posted on 18 Jun 2024 08:22 PM
I did and it showed the same result
Message posted on 20 Jun 2024 09:45 AM
Could you post it? It would be useful to see the exact numbers
Message posted on 22 Jun 2024 04:25 PM
Message posted on 22 Jun 2024 04:31 PM
According to the stats you were downloading at 53Mbps
If you are speed testing at that point the highest speed would be the remaining 6Mbps.
Message posted on 23 Jun 2024 04:04 PM
No one was in the house but me and I was not downloading anything, I tried to access something online but it was super slow which is why I did the speed test?
Occasionally speed.com shows I do get 50+ mbs but recently it's closer to 5mbs, although the sky app always says I have 54?
Message posted on 24 Jun 2024 07:37 AM
@Turlo77 you can see for yourself that when you took that screenshot test the WAN download connection was running at 53Mb/s. Many devices will use bandwidth when in standby to download updates etc so it could easily be that.
