9
This discussion topic has been answered Discussion topic: Changing ssid wifi name
This message was authored by: Jamesnich24
Im trying to change my wifi name in the router settings when clicking save comes up with error code no option to change this in the app any help would be appreciated
Avatar for Jamesnich24
This message was authored by: Jamesnich24 Answer
Re: Changing ssid wifi name
Legand that worked thanks for the help @jamesn123
@Jamesnich24
Do you have the Sky Max hub?
I am NOT a Sky Employee
No just a regular one
@Jamesnich24  How is the device that you are connected to the router to make these changes, as it is best to do this through a wired connection, rather than over Wi-Fi.
Right i see im using my phone on wifi would it be better using my laptop on ethernet ?
@Jamesnich24
Yeah try via ethernet
This message was authored by: MercifullUK
Is there a workaround for those of us who do not have an Ethernet device?
@MercifullUK
Only to try different web browsers: Safari seems to be the least likely to succeed.
Urgh. All my devices are apple lol. I'll see if I can use my work laptop tomorrow and update the thread if successful.
