Discussion topic: Changing bandwidth
This message was authored by Bettyboo123x This message was authored by: Bettyboo123x
Changing bandwidth
I'm trying to split my router into 2.4Ghz & 5 GHz.
I have followed the instructions by logging in using 192.168.0.1 & I can login, see what I need to do but every time I try to click apply it's kicking me off & saying this page can't be found - check your internet connection. I have tried this using wifi and running off my mobiles 4G & both end up with the same result
any ideas?
This message was authored by Skull+Treaty This message was authored by: Skull+Treaty
Re: Changing bandwidth
@Bettyboo123x
Are you using an iPhone? Is so, try a different browser or if possible a device connected to the Hub by an ethernet cable.
"Sometimes, the only choices you have are bad ones, but you still have to choose"
Bettyboo123x
Yea I'm using my iPhone.
I have tried it on Google & safari and both do the same.
do you think a computer would work better?
thanks
@Bettyboo123x when the hub reboots after you apply any changes your device will be disconnected. Once the hub is fully back up which takes 4 or 5 minutes log in to the hub again. If you have changed the SSID as part of your changes then you will need to re-connect your device to the wifi first.
As piinted out devices running ios have issues so the changes dont always stick. Easiest and quickest ona windows device connected by ethernet.
