Discussion topic: Change wifi connection
This message was authored by: Davidleigh
Message posted on 31 Jul 2025 02:56 PM
My pc is showing poor connection. How do I connect it to the WiFi extender instead?
Find out more
Message posted on 31 Jul 2025 03:49 PM
Re: Change wifi connection
@Davidleigh if you have the white Sky hub and WiFi Max pod extenders you can't it is all automatic. To optimise that system's performance try moving the pod nearer the hubto improve backhaul speed. The okder black hub and boosters are similar but far less advanced.
