Discussion topic: Change to faster broadband now wifi is crap
Message posted on 05 Mar 2025 08:55 AM
Message posted on 05 Mar 2025 09:22 AM
Re: Change to faster broadband now wifi is crap
@Wmart increasing spped to the hub wont help,wifi speeds in your home. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Message posted on 05 Mar 2025 10:02 AM
Thanks.
Just wired that wifi was good round house before upgrading to a better speed boadband.
Are the white sky q broadband boosters any good?
