Discussion topic: No internet connection
This message was authored by: Rosie25
A couple of houses up from us have been having their internet connected today. Since openreach have come out we have no internet connection.
Re: No internet connection
@Rosie25
Might be unconnected. If you haven’t done it already use the below link to check to see if there are any problems or outages nearby
(For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support).
