Discussion topic: Carole
Message posted on 13 Dec 2024 10:37 AM
Carole
No internet companies in my house in Runcorn there a technicil problem in my area
Message posted on 13 Dec 2024 10:57 AM
Re: Carole
@Cazie1959 if you know thst there is an issue affecting lines in your area there is nothing you can do tonspeed up getting them fixed. If you want to check Sky arexaware run the Service Checker in the My Sky app over a mobile connection. If thst doesnt tell you Sky know about te issue call them as that starts the clock for compensation should the fault not be fixed by next Tuesday night.
Message posted on 18 Dec 2024 06:16 AM
Re: Carole
Ok, thanks.
