6
This discussion topic has been answered Discussion topic: Cannot connect to work vpn
This message was authored by: Morksmum
Since changing to Sky, I'm unable to connect to work VPN.
already tried -
cookies and caches files have been deleted cached DNS has been flushed
the VPN works on 4G/5G mobile data
turned Sky Hub  off for 1 full hour
switched off IPv6
enabled Upnp
Error message says Can’t connect to  VPN. The specified port is already open
can anyone suggest anything more, I'm currently unable to work from office due to health issues so need this sorted as soon as possible.
Avatar for Morksmum
This message was authored by: Morksmum Answer
Re: Cannot connect to work vpn
No, how do I do that?
This message was authored by: Me134
already tried -
switched off IPv6
enabled Upnp
Firstly disable Sky Broadband Shield.
Then try changing the DNS preferred and alternate address on your device to Googles 8.8.8.8 and 8.8.4.4
https://helpforum.sky.com/t5/Broadband/Sky-Boardband-VPN-Issues/m-p/5303152
Not a Sky employee
Sky FTTP 500Mb to Max Hub
This message was authored by: Tommy2
My brother had this problem when on certain networks, can you try speaking to your work IT team ? as they may come across this a lot and have a way of working around it.
Sky Ultimate TV with Sky Cinema on Sky Steam Puck with WI-FI
Sky Full Fibre 500mbps
Avatar for Morksmum
Thanks, yes I've already tried these too (or my IT support guy has)
Have you confirmed that you are on a 1:1 share through the MySky App?
If so then you can request a non-shared public IPv4 address through the VPN form below. Make sure to explicitly ask for this.
https://www.sky.com/help/forms/vpn-configuration
Not a Sky employee
Avatar for Morksmum
Apologies, you have to check through the web interface at https://192.168.0.1/ Log in with admin plus the original wifi password printed on the hub.
You can find it impossible to log in on desktop but my mobile works fine, you just have to pinch within the details to expand it big enough to read.
Not a Sky employee
