Discussion topic: Cannot access my broadband settings
This message was authored by: Ramone1
Message posted on 02 Jun 2024 08:44 AM
I cannot change the settings from pg to 18 as it is restricting my work sites.
Find out more
Message posted on 02 Jun 2024 08:55 AM
Re: Cannot access my broadband settings
@Ramone1 check you are using the Sky id linked to the sccount as only the account holder can change settings. If you are sure you are call Sky to get the id sorted.
