Discussion topic: Can’t connect to my tv.
Message posted on 13 Apr 2024 07:46 PM
Broadband works on all other devices but won't connect to my tv. I've tried resetting the settings and reset the hub and still no success. Says to check ip address with is 0.00 just now. I don't know what else to try I can connect everything else just not my tv
Message posted on 14 Apr 2024 07:10 AM
Re: Can’t connect to my tv.
@Kayleigh40 as a first step unplug or switch off the power to your TV until the power led goes out then reconnect it which should make it reboot. When going into the TVs settings make sure you choose the setting to get network details from the router the desscription varies but it is normally the default. Once connected to the wifi then thecT`v should get an IP address between 192.168.0.2 to 192.168.0.254 which means it can connectvtomthe internet.
