8
This discussion topic has been answered Discussion topic: Can’t connect phone to Sky Hwb
This message was authored by: AlyKJ
Hi, we have just had Sky Q and talk, which we should receive and send phone calls through the internet. There isn't anywhere on the Hub  to plug the telephone  in. The hub serial  number is ER115. Have I got the wrong hub? My confirmation letter stated that I would have a 4.2 hub. Kind regards Aly
This message was authored by: Highlinder Answer
Re: I think we’ve been sent the wrong sky hub
@AlyKJ  The ER115 is an old router. The least you should have been sent was the Sly Broadband Hub. If you have calls that go through VOIP. This can be checked in plugging your phone into the normal phone socket and if you get a dial tone then it has not changed. If you get nothing then you will need to call Sky.
Avatar for AlyKJ
Re: Can’t connect phone to Sky Hwb
@AlyKJ
Are you new to sky or an existing customer?
What broadband package do you have? Superfast fttc or ultrafast fttp?
A Q Hub  (ER110/115) would be incorrect for Sky Talk Internet Calls as it doesn't have a BT jack socket or an internal analogue telephone adapter.  The appropriate hardware is a Sky Broadband Hub or Max Hub.
Avatar for AlyKJ
@cookiemonsteruk
Hi. I'm an existing customer. I think the problem is that we have Sky talk and the calls should go through the internet. Our confirmation letter said we'd have a 4.2 hub but ours is serial codeER115 and doesn't have anywhere to ok g the phone in. It looks like we have been sent the wrong hub.
Kind regards Aly
Avatar for AlyKJ
@TimmyBGood  I've tried to call but can't get past the automated messages
@AlyKJ
What does it say in my orders in your my sky app?
What is the reason for the new hub, upgrade to ultrafast etc?
Avatar for AlyKJ
@cookiemonsteruk
We upgraded to Sky Q and super fast broadband with talk through the internet.
the order does say 4.2 hub. So it does look as though we've been sent the wrong one.
