This discussion topic has been answered Discussion topic: Cal me
Message posted on 26 Apr 2025 06:47 PM
Call me ps
Message posted on 26 Apr 2025 06:49 PM
No one will call you. If you’re not already aware the Sky Community is a customer led discussion forum where Sky customers are available to help other customers and you aren’t contacting Sky Customer Services.
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Message posted on 26 Apr 2025 06:48 PM
Re: Cal me
Wi fi didn't work
Message posted on 26 Apr 2025 06:53 PM
Re: Cal me
Your duplicate thread has been removed as you've had advice on this one.
