Discussion topic: Internet issue since morning
This message was authored by: Shakeela2
Hi our internet is not working since morning 8am. We dont know whats going on and its frustrating. Can you kjndly fix it as its been a whole day. Otherwise well think of changing our broadband supplier.
Re: Internet issue since morning
@Shakeela2
If you’re not already aware the Sky Community is a customer led discussion forum where Sky customers are available to help other customers and you aren’t contacting Sky Customer Services.
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
In the UK the service level agreement between ISP’s and Openreach for fixing a fault is 2 WORKING DAYS.
The below link explains the Ofcom agreed auto compensation scheme which Sky operates for when there is a TOTAL loss of Sky Broadband or Sky Talk for UK customers.
https://www.sky.com/help/articles/auto-compensation
If you have a total loss of service and it isn’t fixed after two full WORKING days from when Sky are notified of the fault, you will become eligible for it. It’s applied 30 days after the fault has been repaired and will come in the form of a credit appearing on your Sky account (from 01/04/24 the rates are £9.76 per day). There is no equivalent scheme in place for customers in the Republic of Ireland.
As Sky broadband discussed here is a domestic set up there is no extra or quicker support for those working from home.
▪️I AM NOT A SKY EMPLOYEE ▪️
