Discussion topic: CAT 5E socket and Sky Wifi Router
Message posted on 24 Jun 2024 09:02 AM
My daughter has moved in to a flat which has a CAT 5E socket fitted on a wall but no other BT socket...if I order a Sky a Sky WiFi router SR203 will this all work?
Message posted on 25 Jun 2024 10:19 AM
Re: CAT 5E socket and Sky Wifi Router
No the Sky router would need to connect to either an Openreach ONT via RJ45 or via an Openreach master socket via RJ11 depending on the type of technology in use at the property.
Message posted on 25 Jun 2024 10:26 AM
If it's in the UK, putting the address into the BT Wholesale Availability Checker should indicate which provisioning type is applicable.
Message posted on 25 Jun 2024 11:31 AM
@jamesn123 Thanks for the advice!
Message posted on 25 Jun 2024 11:32 AM
Thanks @TimmyBGood
