Discussion topic: Ethernet cable is too short to reach the PC and hub
Message posted on 19 Jun 2024 02:02 PM
I've tried connecting the PC via wifi but the signal isn't strong enough to support online meetings.
My home office is upstairs in a bedroom and the broadband hub is on the ground floor in the hall. How do I go about connecting the PC to the/a hub?
Message posted on 20 Jun 2024 10:09 AM
Re: Ethernet cable is too short to reach the PC and hub
Booster, long ethernet cable or powerline are your best options
Message posted on 22 Jun 2024 09:21 AM
Hi. Thanks for hour reply. However, it's not practical to have a cable running from the far side of my home office, across the landing, down the stairs and across the hall (that sounds like we have a big house, but we really don't!). I assumed Sky or Open Reach could fit an additional av. socket in the office (aka bedroom), but I can't find a way to request this on the Sky website/ App. The help chat just takes me round in circles.
Message posted on 22 Jun 2024 09:33 AM
No, that's not something which either an ISP or Openreach will do: it's outside their remit. You'd need to get a local handy person, knowledge electrician or specialist network contractor.
Message posted on 25 Jun 2024 10:06 AM
Hence why I suggested a booster and/or powerline adapters as well which dont involve running an ethernet cable through your house. Alternatively you could run the ethernet cable around the outside of your house tacked to the brickwork if you live in a detached or semi detached house.
Message posted on 25 Jun 2024 11:34 AM
Hi James. Thanks for our advice. I'll be honest, I'd absolutely no idea what a booster is. I've just googled it and it looks like something I just plug into an electric plug socket costing between £15-£25.
Is that right? If so, that's a fabulous solution. Thank you!!!
Message posted on 25 Jun 2024 11:38 AM
So a booster would be a WiFi extender that you plug in and pair with your hub, it then provides a signal itself which effectively 'boosts' the signal in that area. However 3rd party ones can be hit & miss so you may want to consider getting one directly from Sky.
Powerline adapters essentially carry an ethernet signal over your existing electrical wiring, so you plug one adapter in next to your router & the other next to the device you want to connect via ethernet (e.g. PC) then you essentially have an ethernet connection without the cable going through your house.
https://www.tp-link.com/us/powerline/
