Discussion topic: Buffering wifi
Message posted on 29 Jul 2026 08:16 AM
Buffering wifi
Hi, since having fibre 500 I'm having problems with Wi-Fi always keeps buffering, somebody from sky was suppose to ring me however still not heard from you!
I can only get Wi-Fi in main roombedrooms and garden a no go!
help please
Message posted on 29 Jul 2026 09:15 AM
Re: Buffering wifi
@Diane150 you are not talking to Sky but yours is a frequent issue. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
