Discussion topic: Buffering and slow loading on MacBook Air
Message posted on 07 Jun 2026 09:52 AM
I have Sky 300 Broadband package. Usually good enough for TV and two laptops. But recently there is slowness on the Macbook Air and buffering - all times of day. Never had this before even with reduced speed Broadband. Tests find download speeds as expected. And I do not have this issue on TV and other work laptop. Any suggestions? Could it be a laptop issue? Or is it that the network has become busier? Or something else?
Message posted on 07 Jun 2026 09:56 AM
Re: Buffering and slow loading on MacBook Air
@Mitch63 wrote:I have Sky 300 Broadband package. Usually good enough for TV and two laptops. But recently there is slowness on the Macbook Air and buffering - all times of day. Never had this before even with reduced speed Broadband. Tests find download speeds as expected. And I do not have this issue on TV and other work laptop. Any suggestions? Could it be a laptop issue? Or is it that the network has become busier? Or something else?
The fact that it's just the one laptop points the finger firmly at itself most probably. Is it also a work laptop? Is a VPN in use? Is the other laptop also a Macbook Air?
300Mbps is more than adequate for that use by the way, download speeds don't affect internal wifi speeds.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Message posted on 07 Jun 2026 10:00 AM
@Mitch63 From an earlier post by @jamesn123
Try disabling Sky Shield & iCloud relay.
Not a Sky employee
Message posted on 07 Jun 2026 10:07 AM
Thanks. Yes it is unusual that only one device. The Macbook Air not a work laptop. Other one is a work. Not aware of a VPN but will check this out
Message posted on 07 Jun 2026 10:09 AM
@Mitch63 wrote:Thanks. Yes it is unusual that only one device. The Macbook Air not a work laptop. Other one is a work. Not aware of a VPN but will check this out
Try the solutions given by James first perhaps, I only found it after replying initially.
Not a Sky employee
