4
This discussion topic has been answered Discussion topic: Broken DSL cable
This message was authored by: SNARES
Broken DSL cable
Dog has chewed through my purple DSL cable, do Sky replace these? Or is there somewhere I can purchase a new one?
Re: Broken DSL cable
@SNARES
That's either 'RJ11 to RJ11' (if the ends are the same size) or 'RJ11 to BT jack' (if they are not)
Both varieties are widely available online: there are numerous Sky-branded examples on eBay, but a generic one should work just fine.
@SNARES
Avatar for SNARES
Thank you mate, appreciate your advice on this. Il have a look online then if it doesn't have to be from sky.
@SNARES modt every hardware/diy stire stock dsl cables makecsurectge connectors match the old cable.
Avatar for SNARES
Amazing, thank you very much for your advice.
