Discussion topic: Broadband won't work
This message was authored by: Natasha49
Hi my broadband won't connect
Re: Broadband won't work
I have moved your thread to a more appropriate forum
@Natasha49 Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
