4
This discussion topic has been answered Discussion topic: Broadband updgade equipment received
This message was authored by: nick_staf
Our broadband is being updgraded fron super fast to full fibre.  Equipment was arriving today  - we have only been sent a cable....  I was expecing a new hub, but does this mean our old kit (hub and booster) will still work with the updgrade and we don't need a new one?
This message was authored by: GD1 Answer
Re: Broadband updgade equipment received
@nick_staf  If you have a Sky Max or Sky Broadband hub then all you need is the ethernet cable, a ONT will be installed for the Full Fibre service.
@nick_staf
Do you currently have the black Broadband hub? That apparently should be compatible with FTTP by using an ethernet cable, If current customers don't opt to add a WiFi Max subscription the cable (described as a conversion kit) is what is sent out.
Avatar for nick_staf
I think that will be it then.  Yes we do - and it is an ethernet cable we have been sent.
thank you.
