7
This discussion topic has been answered Discussion topic: Broadband speed
This message was authored by: Nigel43
Broadband speed
Over the last few months, we have experienced huge variations In our tested speed using Ogla speedtest, variations from 113mbps down to 1.8mbps. Sky tells me that all is ok having had OpenReach out to us twice. Gone through the router reset procedure many times, sometimes it improves, back above our standard 100 speed but only for a few hours then it drops off again. Any chance that the router is not ageing very well as we've had it for many years now?
Avatar for Nigel43
This message was authored by: Nigel43 Answer
Re: Broadband speed
Folks, you're never going to believe what I've discovered. In January, I took delivery of a Bogist C1 Pro off-road E-Scooter to help me walk our Malamute Anika around our local farm (74 years old, with bad hips...) The router is in the living room, whilst the scooter lives and is charged in the hallway. The goddamn charger when operating, dependant on how much current is needed by how low the battery is at the time, directly affects the router operating speeds!! Having moved the charging station to the shed, everything works fine! The damned charger is obviously emitting some sort of EM interference that screws with the router signal!! Everyone BE AWARE.
Re: Broadband speed
@Nigel43
Could you post your router stats
Avatar for Nigel43
Re: Broadband speed
Thanks for your suggestions sir, I have just tried every combination that yourself and Sky offered to access the router and a few I thought up myself and I can't get passed the password/username screen and although I'm 74 great care was taken to do it right. Currently although Sky checkup has told me nothing is wrong after yet another reset and 1/2 hour pause before use, it's showing 18.6mbps...
Re: Broadband speed
@Nigel43
Are you using an Apple device & Safari? If so try using a different browser. The login should be;
Username: admin
Password: sky OR your default WiFi password on newer routers.
I am NOT a Sky Employee
Avatar for Nigel43
Re: Broadband speed
Stats as follows
Router Statistics
System Up Time: 00:31:09
Port
Status
TxPkts
RxPkts
Collision Pkts
Tx b/s
Rx b/s
Up Time
WAN
MER 51500
69323 0
3165
6596
00:29:16
LAN
Down 0
WLAN (2.4 GHz)
Up
6293 6
00:29:22
WLAN (5 GHz)
Up
103512 73932 0
36686
00:29:18
Broadband Link
Downstream
Connection Speed
128600 kbps
Line Attenuation D1(45.6 dB), D2(0.0 dB), D3(0.0 dB)
Noise Margin
2.9 dB
Upstream
13389 kbps
UO(0.0 dB), U1(0.0 dB), U2(0.0 dB)
4.0 dB
Poll Interval:
Seconds (at least 3s): 10
Set Interval
Stop
Re: Broadband speed
That appears to be a G.fast connection, which means you should be using an SR204 Sky Broadband Hub from 2019 at the earliest.
Avatar for Nigel43
Re: Broadband speed
Re: Broadband speed
@Nigel43 glad you found the issue. One of the disadvantages with the G.Fast system is that the carrier frequencies used are quite easily disrupted by other devices such as Powerline networking adapters and now your mobility scooters charger.
G.Fast is not going to be used in the future as full fibre lines replace copper phone lines..
