Discussion topic: Broadband speed
This message was authored by: Cromdubh
Broadband speed
I have just connected to Gigafast broadband which is supposed to be around 900 mbs download but when I run a broadband checker it says getting around 100mbs. - Jimdec12
Re: Broadband speed
@Cromdubh
Are you using WiFi or ethernet?
I am NOT a Sky Employee
Avatar for Cromdubh
Hi using tester on my mobile so via wifi
Avatar for Cromdubh
Re: Broadband speed
Hi thanks for replying I was using broadband tester on mobile so over wifi
Re: Broadband speed
@Cromdubh
Oh do you mean your Sky checker is only showing 100mbps? Can you post a screenshot of it?
Avatar for Cromdubh
Re: Broadband speed
Re: Broadband speed
@Cromdubh
Yeah so your never going to get 900mbps over WiFi, neither your router nor likely your phone support WiFi 6 which is the first building block to try and achieve those kinds of speeds over WiFi.
If you want to check the actual speed coming in to your router you need to use an ethernet cable.
This message was authored by: daveNOS
Re: Broadband speed
@Cromdubh Try running the test with your VPN switched off (I can tell your using one by the key symbol), that may be limiting the speed.
Avatar for Cromdubh
Re: Broadband speed
James and Dave thank you so much for your input. It is starting to make sense to me now - my 60+ brain is near frazzled and as you have guessed I'm not that tech savvy.
I DO really appreciate your time and effort. Have a great rest of the day  - kind regards
