Discussion topic: Broadband speed capped at 28
Message posted on 10 Jun 2024 07:35 PM
Message posted on 10 Jun 2024 11:07 PM
Re: Broadband speed capped at 28
A throughput issue can be difficult to identify. I have had similar issues and it turned out to be an issue with parameters further upstream on the backbone equipment with a fault there that eventually got fixed after 60 or so days... It can be the DSLAM issue with parameters and at the exchange with it electronics on a line card in the exchange card itself.
I suggest first posting your router stats to confirm it isn't capped at the DSLAM, there are instructions at the top of this area of the forum that explain how to post those stats. Also, the stats from the diagnostics would be useful that report the actual speed that you have been getting historically over the previous 7 days I believe.
And a throughput speed test from a wired connection to the router to support the throughput fault
Message posted on 11 Jun 2024 09:35 AM
Thanks for the reply. I've attached the stats but can't find anything for historical diagnostics when I look at the Sky hub. The only historical record I've come across is the speed history when I run diagnostics on My Sky. Is this what you meant or are you able to guide me to the right page?
Message posted on 11 Jun 2024 10:10 AM
Well, the router stats show you are connected to the DSLAM, so the broadband line itself is good. Engineers do not need to visit your house as the fault isn't on the broadband line to the DSLAM. But the historical information on throughput which you did post correctly shows a throughput fault which is upstream and a fault on the backbone or exchange line card fault.
Message posted on 11 Jun 2024 10:15 AM
Thanks. What would be the best way to get this resolved? Is there any Sky technical staff on this forum that it can be flagged to so they can escalate it? Like I said in my previous post I just seem to be going round in circles when talking to Sky customer services by phone and all they seem to be able to do is test the line and suggest sending another engineer.
Message posted on 11 Jun 2024 10:23 AM
Your post should be escalated to Sky with information that should be passed to the network team, unfortunately, I'm not a superuser but hopefully one will be along to escalate this clearly shown throughput fault to the network team.
Please ensure when chatting to Sky that you insist that the broadband line and DSLAM clearly show no issue with the broadband line and hence no requirement to send engineers to your house or DSALM.
The issue is further upstream with broadband line card fault at the exchange or capacity issue/contention issue on the backbone.
Message posted on 11 Jun 2024 04:27 PM
Message posted on 12 Jun 2024 09:09 AM
Just a hopeful bump in the hope that a superuser spots this and can flag it to Sky
Message posted on 12 Jun 2024 09:34 AM
Hi @noshadow
Your post has been escalated to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Just look out for the chat bubble to start the conversation.
Here's more information on how Community Messaging works - https://community.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Tom
Message posted on 12 Jun 2024 09:35 AM
@noshadow the pist was escalated yesterday by a superuser the team should be in touch when they pick it up.
Message posted on 12 Sep 2024 09:14 AM
Hi,
I have exactly the issue as the original post. 4th BT Open Reach eng coming today and lost the will to live with Sky call center. This started 5 weeks ago and, I have had new Hub/Router, new master socket etc.
BT Open reach can see 79mb coming to the property but my Sky service checker is shows slow speed to the hub. The levels are constantly below my guaranted minimum of 50.1Mb
Can yu assit advise?
Message posted on 12 Sep 2024 09:44 AM
Current Router Stats
Message posted on 12 Sep 2024 10:18 AM
I wouldn't hold out much hope. Your post might get escalated to a superuser and they'll do more fault finding but in my case Sky basically gave up. They said there was nothing more they could do and that I just had live with the slow speed.
The upside is that I left sky broadband immediately and my new provider is consistently giving speeds of 65mbps or above so it was clearly a sky issue and not with the line. Because Sky were not giving the guaranteed speeds I had the right to exit my contract without any early termination charges so don't let the risk of getting penalised put you off going elsewhere
Message posted on 12 Sep 2024 12:16 PM
@noshadow Posts don't get Escalated to Super Users, they get escalated to The Community Messaging Team who are Sky staff, Super Users are not Sky staff.
