Discussion topic: Broadband shield settings not loading
This message was authored by MH19 This message was authored by: MH19
I am trying to change my broadband shield settings and the stage one does not load at all, or sometime the stage 2 comes up and you can't change the settings, the save settings just greys out. Is anyone else having this issue?
Re: Broadband shield settings not loading
@MH19
Try clearing your browsers cache & cookies or using a different one
I am NOT a Sky Employee
MH19
Thanks @jamesn123  I have just tried and no luck. It's on the webpage and on the app.
@MH19
Unfortunately you will need to call to get it sorted then, this can sometimes happen
