Discussion topic: Broadband router
Message posted on 11 May 2024 01:40 PM
Broadband router
I have recently changed my broadband to fibre optic from copper, I now have 2 routers & need to return one. The engineer used the existing router so I'm I ok to return the new one or is it linked to my account
Message posted on 11 May 2024 01:45 PM
Re: Broadband router
Are both routers exactly the same? i.e the sr203 model
Message posted on 11 May 2024 07:22 PM
Yes they are
Message posted on 11 May 2024 07:24 PM
Strange , the idea would be keep the new one and return the old but its up to you
Message posted on 11 May 2024 07:40 PM
The engineer connect the service to the old router so I was going to send the new one back ( new as in it only came a few months after the first one) but wasn't sure if it was connected to a soecfic account. Do you know if they are linked..?
Message posted on 11 May 2024 07:43 PM
They are not linked to anyones account. So when you send one back it will likely end up with some one else
Message posted on 11 May 2024 09:03 PM
Thank you for advice appreciated
