Discussion topic: Broadband repeatedly dropping out
This message was authored by: Eric+Hughes
There has been no internet for over an hour. It has regularly been dropping out for the last several months, when I last called to complain I was told it's because I don't have fibre. Fibre isn't available in my area. we're in a contract where you're obliged to provide internet and repair faults in a timely manner. This is an ongoing issue that you have failed to resolve.
You need to offer a resolution, either an engineer to fix the fault or a new router
Re: Broadband repeatedly dropping out
@Eric+Hughes
This is predominantly a customer led discussion forum where Sky customers are available to help other customers. You aren’t contacting Sky Customer Services by posting here.
If your broadband still isn’t working this morning and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
Its worth adding that for customers working from home remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
