Discussion topic: Broadband down
This message was authored by: SW110
Broadband down
I have done all the steps to fix it, but I still have no broadband connection. Power and WiFi lights are green, but internet light is orange.
Re: Broadband down
@SW110
Based on the time of your post it may be overnight essential maintenance but not sure they do that on a Sunday night.
If your broadband isn’t working this morning and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
Its worth adding that for customers working from home remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
▪️I AM NOT A SKY EMPLOYEE ▪️
