Discussion topic: Broadband problem
Message posted on 15 Apr 2025 08:25 PM
Broadband problem
Hello
this is happening almost every day. There are only two green lights on my sky box and I can't use the Wi-Fi or stream anything. Please can something be done about this!
Message posted on 15 Apr 2025 08:27 PM
Re: Broadband problem
@Katewhits In case your not aware this is a customer helps customer community, as such we can't do anything about it.
First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
@Katewhits
Wi-Fi is the connection between devices and your router. Broadband is the internet connection provided by your ISP to your dwelling.
This should determine if there's an identified fault affecting multiple households.
