Discussion topic: Broadband poor
This message was authored by: Joe112
Broadband poor
When I check my router it says I'm receiving 502mb to it but having had no issues for months, I am now getting, for example, 9mb to my computer. Noticed it mid afternoon and getting steadily worse. Max I've had this afternoon is about 50mb but generally hovering around 20 or 30, not good enough Sky
This message was authored by: JPR007
Re: Broadband poor
@Joe112 Sounds like a Wi-Fi issue rather than your actuall internet connection, full fibre generally either works or doesn't. Have you tested the connection on a wired device?
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
