Discussion topic: Broadband outage
This message was authored by: Noyan
Broadband outage
Out for 15 mins !!!!!
Avatar for Noyan
Re: Broadband outage
Still no signal over 30 mins now !!!!
@Noyan
You are just telling fellow customers here.
The first thing to do is check to see if there are any outages nearby via this link https://www.sky.com/servicechecker
@Noyan
No terrestrial ISP guarantees uninterrupted service.  If the connection to your individual address has failed then the Openreach target time to fix would be by the end of Tuesday.
