4
This discussion topic has been answered Discussion topic: Sky fibre
This message was authored by: excalibur2
Sky fibre
Recently got Sky fibre installed.......I get almost 500 mbs speed in the room where the router is......At the other end of the Average 28 mbs. small house...bungalow.What's happening here?
Martin Tiernan
This message was authored by: Giggsy1977 Answer
Re: Sky fibre
  • Once the signal has been through a few walls at the other end of the property it's condiserably less powerful that it is in the same room the router is situated.
You could try changing the WiFi channel?
If connecting devices with ethernet isn't an option you could contact Sky for a signal booster as part of the Sky Max setup, but there's a monthly charge for that.
I would look at homeplugs. 👍
Not a sky broadband subscriber
Re: Sky fibre
Re: Sky fibre
@excalibur2
That's inherent to WiFi, which is always zero Mbs after some tens of metres or on the other side of a few walls.  This happens more rapidly for 5Ghz than 2.4Ghz signal.
This message was authored by: hqrd
Re: Sky fibre
All they ever blame is the customers set up or use an ethernet cable whats the point in wifi if we have to use a cable?
Re: Sky fibre
Wifi is an iffy technology.
The Sky routers aren't the best for range either. My friend went from BT to Sky and the range suffered (though that wasn't the Sky Max router, it was the SR213).
I have gone with Plusnet and the range is definitely better than the Sky router I had previously (also the 213).
