Discussion topic: Broadband not working
Message posted on 31 May 2026 05:33 PM
Message posted on 31 May 2026 05:41 PM
Re: Broadband not working
@BrookyW
Even if you’ve already tried it the first thing to do is use this link to check if there are any broadband outages or issues locally that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
