Discussion topic: Internet not working
This message was authored by: Mark87871
My internet has stopped working
Re: Internet not working
@Mark87871
Even if you’ve already tried it the first thing to do is use this link to check if there are any broadband outages or issues locally that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
