Discussion topic: Broadband not working
Message posted on 14 Apr 2026 07:54 PM
My router keeps on going on and off internet one minute its green next its red
Message posted on 14 Apr 2026 07:55 PM
Re: Broadband not working
@Jh951
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
