Discussion topic: Broadband not working
Message posted on 20 May 2025 07:18 PM
Broad band not working for days . Need some help now !!! Been 4 days
Message posted on 20 May 2025 07:34 PM
Re: Broadband not working
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
