Discussion topic: My broadband is not working for 3 days
Message posted on 20 May 2025 07:01 PM
Hello,I've been without internet for 3 days and I have tried all the options with the broadband,I have restarted and unplugged and all the things and I haven't solve nothing.Can I have an engineer to come at my home?
Message posted on 20 May 2025 07:04 PM
Re: My broadband is not working for 3 days
@NeculaiAnchidim
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
