Discussion topic: Broadband not working but tests say it’s fine
Message posted on 14 Jan 2025 11:29 PM
Anyone else having the same problem???
Message posted on 14 Jan 2025 11:30 PM
Re: Broadband not working but tests say it’s fine
Me to, saying there's no connection to the hub but it's slowly flashing green but that's all
Message posted on 15 Jan 2025 04:15 AM
There are known problems in the Manchester area but if that isn't your area use the below link to check to see if there are any outages nearby https://www.sky.com/servicechecker
