Discussion topic: Broadband issues
Message posted on 17 Aug 2025 09:53 PM
Broadband issues
Message posted on 18 Aug 2025 05:22 AM
Re: Broadband issues
@MamaCharlie86
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Message posted on 21 Aug 2025 08:36 AM
Thankyou for response. We did all of this. It turned out it was a problem with open reach outside of the property all sorted in a timely manner thankyou.
