Discussion topic: Broadband issues
This message was authored by: Chrishearn
Broadband issues
Our broadband is not working 2 orange lights on our router. It has been like this for the last few days. Comes back on briefly then drops out again.
Re: Broadband issues
@Chrishearn
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault affecting multiple households.
▪️I AM NOT A SKY EMPLOYEE ▪️
