Discussion topic: Broadband issues reverting to 5G
Message posted on 15 Aug 2026 07:58 AM
Our broadband gets really bad at certain times we often have to turn tv off to use wifi
on phone for checking e mail or use 5G
We want to switch to fibre but our outside line is connected to a pole that doesn't and can't support it as advised by open reach engineer
My neighbour with BT had an issue and open reach changed her line to another pole which incidentally is almost outside our place and supports fibre
This means there are now only 2 place's connected to the non fibre pole
Who do I contact at sky to see if this can be done so we can upgrade to fibre
Message posted on 15 Aug 2026 08:06 AM
Re: Broadband issues reverting to 5G
@Babs1955 Sky can only order servicesclisted for your addres so the first thing you check is the Openreach database entry for your address by using this checker Openreach Checker
The output can be difficult to understand if you want help,post a screen shot of the table and the first three lines of the notes after removing the reference to your address.
Message posted on 15 Aug 2026 08:14 AM
Message posted on 15 Aug 2026 09:03 AM
Doesn't seem to like photos
It says FTTP is available and a new ONT may be available
I think the issue with our current connection is that it is connected to the pedestrian crossing which is 5 foot away from the pole and the pole is next to the green box which controls the traffic lights
Message posted on 15 Aug 2026 09:45 AM
@Babs1955 When posting images they are not shown straight away as they need to go through moderation, the images have now been approved.
https://helpforum.sky.com/t5/Did-you-know/Using-images-or-videos/ba-p/3711140#
Your images and videos won't appear straight away, one of the team will have moderate them first.
