Discussion topic: Ethernet connection lights
Message posted on 14 Aug 2026 08:59 AM
We upgraded to Sky Fibre 150 and I have noticed that the ethernet connections on the reverse of the main Sky hub have one steady green light and one steady amber light. I have tried different ethernet cables. Is this normal?
Message posted on 15 Aug 2026 08:54 AM
Re: Ethernet connection lights
Hi @WJD2, I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Message posted on 15 Aug 2026 09:59 AM - last edited: 15 Aug 2026 10:09 AM
That would usually indicate that the ports are connecting at 100Mb/s instead of 1000Mb/s.
Assuming the cables you are using are working properly and are 8 wire, Cat 5e or above, then it will be a setting on the hub somewhere. Just find it and set it to 1000Mb/s, (also known as "Full Duplex" or sometimes "Auto-negotiate").
(Note, very old cat 5 cables will only support 100Mb/s).
EDIT: I've just had a quick look at an old SR203. It's under "Ethernet" and can be set to "Gigabit ethernet" or "Fast ethernet". You want Gigabit.
