Discussion topic: Broadband issues again
This message was authored by: Rupinder
WiFi has dropped again. This past week its dropped every night.
This is very frustrating and not what I'm paying for.
This message was authored by: JackieMK
Re: Broadband issues again
Same here, all day on Friday the 10th of May; yesterday and today every 10-15 min the connection goes down.
I have followed every suggestion made by Sky Services, including turning the mode off completely and starting again.
What is going on?
This message was authored by: 4Dh0k
Mine has done it again tonight at around the same time. So definitely a problem at Sky.
I connected an old Sky and 3rd party router and mine comes on fine. Its an issue relating to the new VOIP tech for landlines. So I presume you have those routers and I light for voice on the front?
If you have the older routers or another you can use, your Internet will be on as it bypasses the voice function. Just have a mobile phone ready should you need one.
Avatar for Rupinder
No i don't have voice one.  It is a black box with 3 lights.
@Rupinder there have been numerous similar reports recently especially this weekend. Broadband delivered over copper phone lines is vulneable to bad weather and this weekend to the extreme solar activity. It is impossible to know exactly what is causing your issue but it continues call Sky and see if they can get Openreach to check your line for faults.
