Discussion topic: Broadband issues ME2 kent
Message posted on 08 Apr 2024 09:39 AM
Message posted on 08 Apr 2024 10:04 AM
Re: Broadband issues ME2 kent
As this is a customer helps customer forum we can't say why your connection has gone down so does anything show here for you:
https://www.sky.com/help/servicestatus/your-services/broadband
@Suziewoozy you are notvtalking to Sky in posting in the forum but even if you were it is unlikely they could tell you the exact cause. There are 10s of millions of Openreach lines and unfortunately things break and have to be fixed. I would check Sky are aware of the fault by running the connection test in the My Sky app which should tell you if Sky are aware of a fault if they arent call them to report it.
Message posted on 08 Apr 2024 10:09 AM
Mine is also down in me2 but apparently sky are aware of the fault and are working to fix it 🤞🏻
Message posted on 08 Apr 2024 10:27 AM
Broadband outage in Chatham Medway
I have not been able to log into work since morning becuase of broadband outage in the ME4.
Anyone knows what is happening?
Message posted on 08 Apr 2024 01:54 PM
No internet in Medway
I'm in Rochester, Kent and my Internet is down, any one else?
Message posted on 08 Apr 2024 01:56 PM
Re: No internet in Medway
No internet in chatam all day
Message posted on 08 Apr 2024 02:05 PM
Yes I have no internet since 6 am
Message posted on 08 Apr 2024 02:11 PM
Same here in ME5, no internet all day. I got a text at around 2pm which said it was back up but it isn't! I hope they are still looking into this as it is a bit concerning!
Still no Internet in Gillingham Kent, first occurred in the early morning (08/04/2024).
Message posted on 08 Apr 2024 02:34 PM
Same. No internet in ME3 all day. Received text @ 2pm, but still isnt working.
Message posted on 08 Apr 2024 02:46 PM
ME7 still nothing - the online tests don't even work for me now...
Message posted on 08 Apr 2024 03:03 PM
Just a text to say it's back on but it's NOT!!
Message posted on 08 Apr 2024 03:04 PM
Same here
Message posted on 08 Apr 2024 03:06 PM
I'm Rochester I have also had a text to say it's back online but it's not, still no internet and trying to work from home
