Discussion topic: Broadband issue
This message was authored by: Ssheppard
Broadband issue
Morning the Internet indicator is flashing orange and the voice indicator is on consent orange. I have turned everything off for at least a minute and the issue has not resolved.
Re: Broadband issue
@Ssheppard See the links below,!
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to displayed by the software test! This should determine if there's an identified fault affecting multiple households.
Avatar for Ssheppard
Broadband
Broadband hub flashing orange and a consent orange
Re: Broadband
@Ssheppard
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it ~ it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later).
Re: Broadband issue
@Ssheppard
You posted similar on the 1st November and again earlier today. Your third thread has been removed.
