Discussion topic: Broadband is slow
This message was authored by: Heidi57
Broadband is slow
The test run through your site does not agree with another broadband speed checker I have used. The speed is sluggish, and the external checker shows that I am getting 24.56 Mb/s download, which is well below what it should be. Can you check my system please.
Re: Broadband is slow
@Heidi57  Non one here can check anythiong to do with your account.  The speeds shown on the website/mysky app are to the hub, are you running speed tests on a wifi device or over ethernet?
Avatar for Heidi57
When I submitted my query I thought it was to the team at Sky and not the community. I will need to see if I can contact them directly.
I am running the test from my computer, which is using the Wifi.
